Problen with SPA9000+SPA400
Answered Question
Jul 16th, 2009
I have assembled a system with a VoIp SPA400 and SPA9000 and I preduntar several problems:
- The Call ID: not that I'm able to go on display in the SPA942 and the 310-WIP v2 the number of person caller, even though I have not tried it. I downloaded a pdf where you put the configurarion the impedance of the line, the gain, the method, and not with those I am able to configure it to appear on the screens. In the SPA9000 that I have seen in the regional section of call option id, and I have tried all possible ways and nothing. If I could say the configuration of both the SPA400 and the SPA9000 you agradeceria. My location is Spain .
- AA: If I put the automatic operator always gets the message unless the caller dial extension. My need is that last a few seconds, or at the end of the first term of the sentence, you automatically pass the call to the extension of the operator. And for this I have been reading the manuals and other forums around, and nobody says anything for this.
Thanks and best regards.
Correct Answer by NetAgeTrani about 7 years 7 months ago
contact list: aa
this is what I've done......
I know the configuration guide is not complete for administrator/installer
Overall Rating: 5 (1 ratings)
Correct Answer
NetAgeTrani Thu, 09/10/2009 - 10:55
contact list: aa
Patrick Born Thu, 07/16/2009 - 15:26
  • Cisco Employee,
Hi Luis,
Caller ID problems will soon be resolved... refer to this thread:
https://supportforums.cisco.com/message/3093381
I suggest you use the SPA9000 Setup Wizard to easily configure your voice system in a very short period of time:
https://supportforums.cisco.com/docs/DOC-9876
With respect to your AA question, I believe that you're looking for the bargein feature which is described in the SPA9000 Voice System Administration Guide at:
https://supportforums.cisco.com/docs/DOC-9849
Patrick
