I have a problems with SPA3102 FW 5.1.10 (i attach schema of connection and spa configuration)
if i call via fxo - OK
if i call via SIP - OK
if i receive call via FXO - OK
if i receive fax via PSTN fax machine not answer, SPA3102 after some ring end call
there is a possibility to change SPA3102 not hang up if I do not answer with cordless phone connect to fxs port?
I would want that SPA left to ring to the infinite until who it calls does not put down or if until it does not answer the fax.
Best Regarde
Thomas
