CME Fails on cfwd noan to CUE with Disconnect Cause 41
Jul 16th, 2009
I have a multi-site, multi-cme deployment.
CME versions 7.x
Site A: CME/CUE
Site B: CME/CUE
Site C: CME - uses Site B CUE
Among other things :), intermittently, calls are failing to VM on calls directed to Site C: but fwd to Site B:
Calling Number = 313 (Site B:)
Called Number = 777
call-forward noan *400 timeout 3 (3 for testing, 14 live)
Ext. 400 resides on Site B:
Ext direct-to-VM number is *400
When setting call-fwd all *400 I am unable to repeat the issue
When setting cfwd-noan *400 I will hear ring busy sometimes.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
no supplementary-service h450.3
supplementary-service h450.12
ephone-dn 55 dual-line
number 777
label Loans
description Loans
name Loans
preference 1
huntstop channel
no huntstop
I have attached output showing the output of deb ccsip messages. Note the disconnect cause code on the bad call. The good call was placed one minute later.
So, I guess the best question is...how to troubleshoot disconnect cause 41?
Thanks!
Nicholas Matthews Thu, 07/16/2009 - 10:19
  • Red, 2250 points or more
The debugs is actually just the CDR output, so it doesn't help much.
I'm guessing you're running CME between the routers?
Have you tried adding this to both:
voice service voip
no supp sip refer
no supp sip moved
allow-connections sip-to-sip
-nick
Paolo Bevilacqua Thu, 07/16/2009 - 10:21
  • Hall of Fame,
    Founding Member
There is no debug ccsip message in the attachment.
r.stockton Thu, 07/16/2009 - 10:42
oops, debugs included this time.
Can you describe the logic of the following:
no supp sip refer
no supp sip moved
Also, should SIP to SIP be on both CMEs?
Paolo Bevilacqua Thu, 07/16/2009 - 11:00
  • Hall of Fame,
    Founding Member
Before I read further, for voicemail CME C uses IP address of CUE B, not CME B, correct ?
r.stockton Thu, 07/16/2009 - 12:44
This may be dsp related since g.729 is being transcoded for VM. Trying to figure out how to prove this, though....
