remote vpn users get asa as default gateway?
Jul 16th, 2009
My remote vpn users (connect to asa5520 for vpn endpoint) get the asa as their default gateway. How do I make our actual core router their gateway once connected rather than the asa? Its causing them some routing issues and connectivity issues to certain servers. thanks in advance
Ivan Martinon Tue, 07/21/2009 - 07:50
  • Cisco Employee,
The VPN Clients will always get either the ASA as the default gateway or the IP Address they received via this vpn client connection, now to send all traffic from this clients back to your core router then you go ahead and configure your ASA to use a "tunnel default gateway" with:
route inside 0.0.0.0 0.0.0.0 X.X.X.X tunneled
This will send all traffic that is received via any tunnel back to your core router which should be the x.x.x.x
