Moderator Fri, 07/17/2009 - 06:43
Hi add_16,
Can you please give us some more information about your situation and the product you are using or are interested in, so that I can direct your question to our experts?
Thank you,
Cisco Moderation Team
add_16@ymail.com Fri, 07/17/2009 - 12:30
Im using a Linksys SPA941 with 5.1.8 Firmware. I use Peru D.I.D's and have to dial 011511+number for out going calls. i need a Dial plan/string so that i dont have to dial the 011511, just dial the number straight. Local numbers are 7 digit and cell phones are 10 digits. thanks
Alberto Montilla Mon, 07/20/2009 - 10:43
Dear Sir;
All you need to do is to modify the [SIP] Phone dial plan parameter and add the appropriate syntax. Parameter is located at the bottom of the SPA9000 [SIP] tab, login in admin advanced mode. For the syntax please check the administration guide.
Alberto
