Band-Select in 6.0.182.0
Is anyone successfully using Band-select ? I was reading the 6.0.182 release notes and found this comment:
"Band Select and Load Balancing CLI Commands
The config band-select and config wlan band-select CLI commands appear in controller software
release 6.0.182.0, but they are not supported and should not be used. Also, you can ignore the Band
Select Stats information in the output of the show ap stats {802.11a | 802.11b} Cisco_AP command."
Link to the release notes(page 22):
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn601820.pdf
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
