6509 RP fail to boot
Jul 16th, 2009
I have a 6509 that booted up in SP rommon mode. I thought there might be a problem with the IOS so I upgraded to s72033-advipservicesk9_wan-mz.122-18.SXF16.bin on a flash card.
The new IOS is visible and the boot initiates but fails.
Below are most of the messages. Thank you for any ideas.
00:03:05: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
%Software-forced reload
Breakpoint exception, CPU signal 23, PC = 0x402DF844
-Traceback= 402DF844 402DD790 40AC8DC4 40ACFF60 40AD06EC 40AD07F8 40AC60FC 40AC0A6C 4029CF9C 4029CF88
$0 : 00000000, AT : 41600000, v0 : 42350000, v1 : 41CE0000
a0 : 5002FDEC, a1 : 0000FF00, a2 : 00000000, a3 : 50C6CFD0
t0 : 00000028, t1 : 3400FF01, t2 : 34008100, t3 : FFFF00FF
t4 : 402D2368, t5 : 503A2046, t6 : 6420746F, t7 : 64206865
s0 : 00000000, s1 : 414C0000, s2 : 42D30000, s3 : 42D30000
s4 : 00000000, s5 : 00000000, s6 : 00000000, s7 : 00000000
t8 : 00000000, t9 : 00000006, k0 : 82EE65B0, k1 : 045A1E00
gp : 4160B6F0, sp : 50C6D130, s8 : 00000000, ra : 402DD790
EPC : 402DF844, ErrorEPC : BFC19A68, SREG : 3400FF03
MDLO : 00000000, MDHI : 00000000, BadVaddr : 00000000
DATA_START : 0x41490530
Cause 00000024 (Code 0x9): Breakpoint exception
File bootflash:crashinfo_20090716-194313 Device Error :No such device
=== Flushing messages (19:43:13 UTC Thu Jul 16 2009) ===
Buffered messages:
Queued messages:
00:03:06: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:03:06: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:03:06: %PFREDUN-SP-4-AUTOBOOT: Disable autoboot for Supervisor in slot 5
00:03:06: %PFREDUN-SP-6-ACTIVE: Sup in slot 5 is crashing due to RP failed to boot
00:03:06: SP: Failed to send heartbeat poison message
00:03:06: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x42356ad4
PC = 0x402d23ac, Cause = 0x1020, Status Reg = 0x34008002
rommon 3 >
Jerry Ye Thu, 07/16/2009 - 11:59
  • Cisco Employee,
Hi Vincent,
Looks like you have a hardware problem, I will suggest you to contact Cisco TAC.
HTH,
jerry
Zubair.Sayed_2 Tue, 11/29/2011 - 05:46
Hi Vincent
I am having the same error message and wondering if it was a hardware issue as mentione by Jerry or did you manage to resolve this another way?
I am having the same error messages as you.
Z
