configuring NTP server on a 3825 router
Answered Question
Jul 16th, 2009
hello
i want to use the harware calendar of a 3925 router as a ntp server for the lan and i was wondering if the < NTP master > command is all i need? Or that command referce to the software clock . Im a little confused about that.
thanks
Correct Answer by Lucien Avramov about 7 years 10 months ago
you can use the command ntp update-calendar for the hardware clock as per:
http://www.cisco.com/en/US/docs/ios/netmgmt/command/reference/nm_10.html#wp1096194
This way the hardware clock is synced from the ntp source.
If you want to sync the hardware clock from the software clock, then the command you can use is:
clock update-calendar
Yes, you only need ntp master and the stratum level you want to assign to it.
Example: router(config)# ntp master 2
Overall Rating: 5 (2 ratings)
Correct Answer
Lucien Avramov Thu, 07/16/2009 - 13:54
  • Red, 2250 points or more
bkoum Thu, 07/16/2009 - 20:12
And is there any way to set up the harware clock manual or this can be only via synchronization with the software clock.
thanks again
Correct Answer
Lucien Avramov Fri, 07/17/2009 - 20:51
