Is IPS is the functional role of router? or some hardware too?
Jul 17th, 2009
As I understood IPS can be some kind of ISR routers and CAT switches? am I right?
Overall Rating: 3 (1 ratings)
Collin Clark Fri, 07/17/2009 - 05:06
IPS can be performed in IOS on routers. There are some routers that also support an IPS network module so the process is off loaded to the card. AFAIK no switches support IDS (apart from the 6500).
Hope that helps Fri, 08/14/2009 - 04:01
Can you provide some IOS versions that support IPS?
Where I can find this information?
