Policy Based Routing Problem
Answered Question
Jul 17th, 2009
Just wondering if anyone has come across this issue, we have two separate MPLS connections, both are from the same provider and both links receive the same bgp routes, however we are trying to manipulate the routing so that one of the LAN sub-interfaces goes across one specific link and will never go across the other.
Ingress to the the CE router from the core is fine as we have stopped the LAN sub-interface (via prefix lists) being advertised so it only knows how to get to the LAN sub-interface via link 1,m it will never go across link 2.
However from the LAN to the core it is using link 2, we have tried to use the following policy based routing and we can see matches in the debug but traffic still prefers going across link 2, I thought once it was matched th epolicy took over and didn't go near the routing table?
interface FastEthernet0/0.201
encapsulation dot1Q 201
ip address 10.10.10.1 255.255.255.0
no ip proxy-arp
ip policy route-map outbound-routing-policy
no snmp trap link-status
no cdp enable
link 1
serial 0/1
ip address 20.20.20.1
(link 2)
serial 0/2
ip address 30.30.30.1
route-map outbound-routing-policy permit 10
match ip address 180
set ip next-hop 20.20.20.2
access-list 180 permit ip 10.10.10.0 0.0.0.255 any log
Correct Answer by pidoshi about 7 years 8 months ago
Could you try removing the "log" keyword from the ACL which is tied to the PBR..This is due to the fact that the log option forces pkts to be process switched and might affect PBR which is done in hardware (depending on HW)
Give it a try..!!
cheers
Pinku
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 07/17/2009 - 01:18
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
"I thought once it was matched th epolicy took over and didn't go near the routing table?"
It should do.
Could you draw a quick topology so we can see how it is laid out. What is 20.20.20.2 ?
Also what device are you applying this PBR on ?
Jon
smithsera1 Fri, 07/17/2009 - 01:42
Hi Jon,
See attached for topology diagram, 20.20.20.2 is the far end of the MPLS link i.e bgp neighbour (PE),router is 2811
Thanks alot
Jon Marshall Fri, 07/17/2009 - 02:06
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Paul
Can't see anything wrong with your config.
Presumably 20.20.20.2 is up and reachable ?
What IOS version/feature set are you running on the 2811 router ?. I had a quick scan for bugs but nothing came up.
Jon
mailaglady2 Fri, 07/17/2009 - 06:46
Hi Paul
I also dont see anything wrong with your configs but try this:
set interface serial0/1
Rui Carlos Antunes Mon, 07/20/2009 - 03:02
Do you have a route (on the IP Routing Table) for the 10.10.10.0/24 network?
Do a "show ip route 10.10.10.0".
If you don't have, the command on the route-map should be "set default ip next-hop 20.20.20.2" (instead of just "set ip next-hop 20.20.20.2").
smithsera1 Mon, 07/20/2009 - 03:40
The route for 10.10.10.0 is showing as directly connected as 10.10.10.1 is configured on the sub-int, I'm just wondering would there be an alternative way of trying to complete the scenario?
Pavel Bykov Mon, 07/20/2009 - 03:56
  • Silver, 250 points or more
Hi. Here is how i'd troubleshoot it.
1. Is the traffic really crossing the interface FastEthernet0/0.201 ? Is it possible that it leaks somewhere else? Just if the show commands really show that traffic is flowing
2. issue "ip route-cache policy" command on the FastEthernet0/0.201
3. try debugging PBR (in the afterhours of course) using debug ip policy command
Correct Answer
pidoshi Tue, 07/21/2009 - 01:32
  • Cisco Employee,
Give it a try..!!
cheers
Pinku
smithsera1 Tue, 07/21/2009 - 04:16
Hi Pinku,
Super stuff, that sorted it...took out the log on the end of the ACL and it works..
Brilliant, tks a mill
Cheers
Paul
