ISDN BRI problem
Ph0kiszar
I have 4 port ISDN BRI and the configuration follow attache. I try to call between site and the ISDN BRI its work only 3 port of 4 port. Currently ISDN working I use command "debug dialer" and test call by command
"isdn test call interface bri 0/0/2 073224017"
the debug show like this
AAA#isdn test call interface brI 0/0/2 073224017
AAA#
*Jul 17 09:51:43.771: BR0/0/2 DDR: Attempting to dial 073224017
AAA#
*Jul 17 09:51:52.695: BRI0/0/2: wait for isdn carrier timeout, call id=0x8276
AAA#
*Jul 17 09:51:58.499: BR0/0/2 DDR: rotor dialout [best] least recent failure is also most recent failure
*Jul 17 09:51:58.499: BR0/0/2 DDR: rotor dialout [best] also has most recent failure
*Jul 17 09:51:58.499: BR0/0/2 DDR: Attempting to dial 1899
*Jul 17 09:51:58.839: BRI0/0/2: wait for isdn carrier timeout, call id=0x8277
AAA#
*Jul 17 09:52:28.499: BR0/0/2 DDR: rotor dialout [best] least recent failure is also most recent failure
*Jul 17 09:52:28.499: BR0/0/2 DDR: rotor dialout [best] also has most recent failure
*Jul 17 09:52:28.499: BR0/0/2 DDR: Attempting to dial 1899
*Jul 17 09:52:28.899: BRI0/0/2: wait for isdn carrier timeout, call id=0x8278
Please advise,How can I make ISDN work fully 4 port.
Ph0kiszar
When I debug isdn q931 then use "isdn test call interface bri 0/0/2 073224017"
AAA#isdn test call interface bri 0/0/2 073224017
AAA#
*Jul 17 10:27:28.871: ISDN BR0/0/2 Q931: RX <- DISCONNECT pd = 8 callref = 0xC3
Cause i = 0x829F - Normal, unspecified
*Jul 17 10:27:28.875: ISDN BR0/0/2 Q931: TX -> RELEASE pd = 8 callref = 0x43
Cause i = 0x809F - Normal, unspecified
*Jul 17 10:27:28.919: ISDN BR0/0/2 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xC3
*Jul 17 10:27:29.595: ISDN BR0/0/2 Q931: Sending SETUP callref = 0x0044 callID = 0x82BF switch = basic-net3 interface = User
AAA#
*Jul 17 10:27:29.599: ISDN BR0/0/2 Q931: TX -> SETUP pd = 8 callref = 0x44
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Called Party Number i = 0x80, '073224017'
Plan:Unknown, Type:Unknown
*Jul 17 10:27:29.647: ISDN BR0/0/2 Q931: RX <- CALL_PROC pd = 8 callref = 0xC4
Channel ID i = 0x89
Exclusive, B1
AAA#
*Jul 17 10:27:38.543: ISDN BR0/0/2 Q931: RX <- DISCONNECT pd = 8 callref = 0xC4
Cause i = 0x8492 - No user responding
*Jul 17 10:27:38.547: ISDN BR0/0/2 Q931: TX -> RELEASE pd = 8 callref = 0x44
Cause i = 0x8092 - No user responding
*Jul 17 10:27:38.591: ISDN BR0/0/2 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xC4
PS. the number 1899 its just a huntgroup of 4 ISDN telephone number that I have.
