How to test V WIC2-2MFT-E1 without PSTN line ?
wahidayat007
Is there any method that I installed V WIC2-2MFT-E1 on 2801 router and test, whether ports are working ?
Any help will be appreciated.
Michael Owuor
You could use a T1 crossover cable to connect one port to the other (or back to back to another router), and configure the PRIs with one side emulating the network side and the other the user side, and then send a call through.
Michael.
Do you mean,
cross/cable
IP-phone--CM---2801<----------->2811
Do you mean like that or if can give me simple senario
thanks
An example of simple scenario:
IP-Phone--CME--2801<--->2811--CME--IP-Phone
Make one side user and other network as described here:
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t3/feature/guide/dt_q931.html
Michael.
Thanks Micheal.
