Local SPAN on 4948, amount of traffic is not equal
Jul 17th, 2009
Hi All,
I have the cisco switch WS-C4948 running IOS 12.2(46)SG and local span session configured:
sw-4948>show monitor
Session 6
Type : Local Session
Source Ports :
Both : Gi1/5-11,Gi1/21
Destination Ports : Gi1/4
Encapsulation : Native
Ingress : Disabled
Learning : Disabled
the total sum (input and output) of the traffic of source ports is not equal to output rate on destination port
Any idea what's wrong?
Thank You
j.mozolik.,
sw-4948#show int g1/4 | i rate
Queueing strategy: fifo
5 minute output rate 760000 bits/sec, 305 packets/sec
sw-4948#
sw-4948#show int g1/5 | i rate
5 minute input rate 654000 bits/sec, 277 packets/sec
5 minute output rate 726000 bits/sec, 399 packets/sec
sw-4948#show int g1/6 | i rate
5 minute input rate 1385000 bits/sec, 330 packets/sec
5 minute output rate 1081000 bits/sec, 374 packets/sec
sw-4948#show int g1/7 | i rate
sw-4948#show int g1/8 | i rate
sw-4948#show int g1/9 | i rate
5 minute input rate 779000 bits/sec, 315 packets/sec
5 minute output rate 803000 bits/sec, 450 packets/sec
sw-4948#show int g1/10 | i rate
5 minute input rate 677000 bits/sec, 199 packets/sec
5 minute output rate 568000 bits/sec, 213 packets/sec
sw-4948#show int g1/11 | i rate
sw-4948#show int g1/21 | i rate
5 minute input rate 844000 bits/sec, 489 packets/sec
5 minute output rate 776000 bits/sec, 334 packets/sec
Pavel Bykov Fri, 07/17/2009 - 04:59
  • Silver, 250 points or more
5 minute average measures interval of about 30 minutes. So there are two possible reasons.
1. set load-interval to 30 (seconds)
2. Counters do not correspond to the mirrored information.
As a side note: One TAC case that i saw about counters were deemed as a cosmetic bug and the results had to be read elsewhere.
