Route Group issue?
Answered Question
Jul 17th, 2009
I am trying to create a route group on CUCM 6.1
Issue is when I go to route group menu and then add new, I do not see all my endpoints listed. It seems like only the endpoints already in other route groups are available for selection.
any advice?
Correct Answer by Jaime Valencia about 7 years 9 months ago
There's nothing wrong with that.
If you already added an MGCP endpoint or H323 GW to another route group or directly selected it in a route pattern it won't be available as a choice next time.
ICT GK controlled for example can be added into several but that's because of the GK and the fact it can route to multiple destinations with routing done outside CUCM.
java
if this helps, please rate
Overall Rating: 4 (1 ratings)
Correct Answer
Jaime Valencia Fri, 07/17/2009 - 07:16
  • Cisco Employee,
  • Hall of Fame,
    2011
java
