Snmp Config
Jul 17th, 2009
Hi ALL:
I am facing a very peculiar issue with SNMP.
Every thing workfine when i put
snmp-server group snmpgroup v3 auth in the running config and save it but once the
switch get reloaded i see this in the running config and my NMS tool do not show that the
router is up.
Any idea why is this happening
snmp-server group snmpgroup v3 auth read notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF
snmp-server group snmpgrp v3 auth
groupname: snmpgrp security model:v3 auth
readview :v1default writeview: <no writeview specified>
notifyview: <no notifyview specified>
row status: active
groupname: snmpgroup security model:v3 auth
readview :<no readview specified> writeview: <no writeview specified>
notifyview: *tv.FFFFFFFF.FFFFFFFF.FFF
row status: active
Chao
Vishwa
carenas123 Fri, 07/24/2009 - 14:58
  • Silver, 250 points or more
Try to reconfigure your SNMP configuration. And try. If still you are getting same problem then only solution is to upgrade it and use some other NMS tool.
vishwancc Sun, 07/26/2009 - 06:06
After doing a lot of research i was able to resolve the issue.
I found that the string is present in the SNMP view internet.
So i excluded the string form the view and after doing that evry thing worked fine.
I dont know what all the command did when i removed it but the issue is resolved.
Before
show snmp view
v1default iso - included volatile active
v1default internet.6.3.15 - excluded volatile active
v1default internet.6.3.16 - excluded volatile active
v1default internet.6.3.18 - excluded volatile active
notifyview internet - included nonvolatile active
*tv.FFFFFFFF.FFFFFFFF.FFFFFFFF internet - included volatile active
snmp-server view notifyview internet excluded.
After
sh snmp view
notifyview internet - excluded nonvolatile active
Chao
Vishwa
