WS-X6148A-GE-45AF module and 12.2.(33)SXH1
Jul 17th, 2009
Hi all,
I couldnt find any clear information regarding the compatibility between 6148-GE45AF interface module and 12.2(33) SXH1 IOS support ? Does anyone know whether this module needs a Rommon upgrade or not ? According to IOS software selector it does not.
I receive "card was not present or an unsupported card found" when I issue "show rom-monitor slot *" command.
Thanks in advance.
Jon Marshall Fri, 07/17/2009 - 08:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dumlu
"I couldnt find any clear information regarding the compatibility between 6148-GE45AF interface module and 12.2(33) SXH1 IOS support ?"
See the release notes for 12.2(33)SXH, specifically this part -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.html#wp4631272
So it is compatible.
This switch is not running in VSS mode is it ?
Jon
dumlutimuralp Fri, 07/17/2009 - 09:32
I know this url. The thing is I though there shoule be a note showing the minimum rommon version for this module rather than just showing the minimum IOS requirement. VSS is NOT running
thank you .
