CUCM 6.2.1 1002-1 upgrade to 6.1.2 1112-2 is not possible .
Jul 17th, 2009
Hi all,
because we run in an extension mobility bug with our current version of CUCM 6.1.2 we wanted to upgrade to the engeneering special 1112-2 where this bug is fixed.
After I logged in to the OS-administration Screen and entered the information for the ftp-Server i can not chose the 1112-2 update file.
The only thing I see is the user and the network locale wich i wanted to install after the upgrade.
I also tried ES 1106-1 but that's the same Problem.
Does anyone know why i cannot chose the ES Update in the dropdown list?
The readme doesn't say anything about incompability with our version of CUCM....
kind regard
Chris
Jaime Valencia Fri, 07/17/2009 - 07:08
  • Cisco Employee,
  • Hall of Fame,
    2011
what is the exact name of the ES file you have???
java
if this helps, please rate
