Unity 5 Failover
balukr
Level 2
Level 2
I'm in process of adding a Unity failover server for a customer, I see there are several engineering specials in CCO for Unity but want to know do I need to apply any of those. In other words is there any known bugs for Unity failover and needed any of those ES before we go live with this server. Currently there is no ES on primary Unity server.
Unity version is 5.0
Exchange - 2007
Unified Messaging
Thanks for your help
Jaime Valencia
It's really not as common as with CUCM the need to install a ES or upgrade in Unity.
If your system has been running fine so far i don't believe you need any ES. Installing ES just because can cause trouble because some need to be installed in pairs, or installing a ES causes another bug for which you need yet, another ES to fix. Unless you have been instructed by TAC or know you're hitting a bug best to leave them alone.
java
if this helps, please rate
java
