Redundant/Load balanced NAT on ASA
Jul 17th, 2009
Hi.
Is there a way of having a single Public IP address and NAT'ing to 2 different IP addresses. Either loads balanced or one as primary and the second in the event of failure??
Basically I would like to do the simplest job of the CSS on an ASA.
To be honest even the load balancing isn't required. Its more important to NAT to one IP generally and then if that IP is down NAT elsewhere.
HELP!
Thanks.
Kureli Sankar Fri, 07/17/2009 - 15:41
  • Cisco Employee,
Sorry. That is not possible. That would be overlapping. We do not support that. It has to be manual or you would have to use CSS Content Service Switch.
