Orange Status LED on WS-C2950G-24-EI
Jul 17th, 2009
As the title suggests I have an orange status LED on the switch. Also, the unoccupied ports in the middle of the switch are solid orange(ports 8-17, with the exception of 9 which has no orange light).
I have been unable to determine the cause of this on my own. The switch is on IOS Version 12.1(22)EA10.
Currently it is running fairly stable with the exception of the lights. The used ports are functional and not losing any packets.
The switch did restart on its own a couple of months ago, however. The command "show logging" displays the following:
1: 00000001, a2: 00000018, a3: 81000001
000053: .May 26 19:46:19: %PLATFORM-1-CRASHED: t0: 00000038, t1: 1000E101, t2: 10000000, t3: FFFF00FF
000054: .May 26 19:46:19: %PLATFORM-1-CRASHED: t4: 802D39B8, t5: A09404D8, t6: 00000000, t7: A09404CC
000055: .May 26 19:46:19: %PLATFORM-1-CRASHED: s0: 00000053, s1: A0900562, s2: 80C11C58, s3: 807F4B30
000056: .May 26 19:46:19: %PLATFORM-1-CRASHED: s4: 807A5F90, s5: 80BF92C8, s6: A090055C, s7: 00000000
000057: .May 26 19:46:19: %PLATFORM-1-CRASHED: t8: A09404C8, t9: 70000000, k0: 00000000, k1: 00000000
000058: .May 26 19:46:19: %PLATFORM-1-CRASHED: gp: 807E26C0, sp: 80BFF500, s8: 80860000, ra: 802B7DE8
000059: .May 26 19:46:19: %PLATFORM-1-CRASHED: EPC: 802B7FCC, ErrEPC: 802D18B0, BadVA: 0xA090056F, SREG: 1000E103
000060: .May 26 19:46:19: %PLATFORM-1-CRASHED: Cause: 0x00000010 (code 4): Address Error (load or ifetch) exception
000061: .May 26 19:46:19: %PLATFORM-1-CRASHED: Signal 10, Exception code (0x0010)!
000062: .May 26 19:46:19: %PLATFORM-1-CRASHED:
000063: .May 26 19:46:19: %PLATFORM-1-CRASHED: Frame 00: SP = 0x80BFF500 PC = 0x802B7FCC
000064: .May 26 19:46:19: %PLATFORM-1-CRASHED: Frame 01: SP = 0x80BFF590 PC = 0x802B5668
000065: .May 26 19:46:19: %PLATFORM-1-CRASHED: Frame 02: SP = 0x80BFF5E8 PC = 0x802B2A14
000066: .May 26 19:46:19: %PLATFORM-1-CRASHED: Frame 03: SP = 0x80BFF620 PC = 0x802B2570
000067: .May 26 19:46:19: %PLATFORM-1-CRASHED: Frame 04: SP = 0x80BFF660 PC = 0x802D32D4
000068: .May 26 19:46:19: %PLATFORM-1-CRASHED:
000069: .May 26 19:46:19: %PLATFORM-1-CRASHED:
000070: .May 26 19:46:19: %PLATFORM-1-CRASHED: -Traceback= 802B7FCC 802B5668 802B2A14 802B2570 802D32D4
Does anyone have any insight to this issue?
Thanks.
Leo Laohoo Fri, 07/17/2009 - 15:59
Could mean anything.
Firstly, if you have a crashinfo file it would be worthwhile if you post it.
Secondly, your IOS is EA10. Didn't this IOS got pulled out of the Cisco IOS Download page because it was a "dune" buggy???
Try upgrading to the EA10a and see if there is improvements.
Hope this helps.
jpeterson6 Mon, 07/20/2009 - 06:16
Here's the full crashfile from Flash:
C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA10, RELEASE SOFTWARE (fc2)
Compiled Tue 08-May-07 11:50 by myl
Signal = 10, Code = 0x10, Uptime 6w1d
r0: 00000000, AT: 00000000, v0: 00000000, v1: A090056D
a0: A090056D, a1: 00000001, a2: 00000018, a3: 81000001
I wasn't aware about the buggy IOS. I'll have to look into trying an upgrade. Thanks for the suggestion.
jpeterson6 Mon, 07/20/2009 - 06:47
I forgot to ask also- do you have a recommended IOS to upgrade to?
Leo Laohoo Mon, 07/20/2009 - 14:48
The crashinfo file isn't helpful. EA10 was pulled out and replaced by the EA10a. You may want to try that.
Before you upgrade, I recommend you read the release notes and do some testing with the IOS of your choice.
