Is it possible add * or # as a prefix in CME 4.1?
Jul 17th, 2009
A client is asking to add * or # as a prefix when they need to communicate between central site and remote site.
is is possible to use * or # as a prefix?
regards
Jaime Valencia Fri, 07/17/2009 - 07:02
  • Cisco Employee,
  • Hall of Fame,
    2011
* yes, # is the default end of dial digit so it's not really used for that
java
if this helps, please rate
filiberto.aguirre Fri, 07/17/2009 - 10:53
hI java,
thanks for your quick response.
Should I define a translation rule and profile ?
Adrian Saavedra Fri, 07/17/2009 - 22:36
  • Gold, 750 points or more
Hi friend,
In addition to wildcard characters, the following characters can be used in the destination pattern:
Asterisk (*) and pound sign (#)-These characters on standard touch-tone dial pads can be used anywhere in the pattern. They can be used as the leading character (for example, *650)
Wildcard symbols such as the period (.), asterisk (*), percent sign (%), plus sign (+), and question mark (?) are not valid in translation rules. The router ignores these symbols when converting a number if they are used in a translation rule.
If helps, please rate.
Regards and good luck,
- Adrián
