07-17-2009 07:49 AM - edited 03-18-2019 11:22 PM
Hello All
I am having problems with Unity 7 and playback. The voice propmts are sometimes choppy and the playback is sometimes speeded up so fast that it is intelligible. It is as if the choppiness is compensated by speeding up the audio. This is happening on the lan, wan and pstn.
I have added Qos through the lan network and the port the unity server connects.
Any advice would be helpful.
The voice on the network is fine.
Feisal
07-23-2009 01:07 PM
Playback speeds is probably a sticky feature that was newly introduced in version 7.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/release/notes/702curelnotes.html#wp62222
You can monitor this defect to see for an upcoming release if that can be disabled.
CSCsz93254 Provide a way to disable sticky playback speed keys
07-24-2009 12:21 AM
Hello Rmai
Thanks for that. It seems that the playback was corrected after more virtual cpu's were addeded to the virtual machine, the dynamic size was changed to a fixed size disk and the box was rebooted. Also some more intensive vm machines were removed. This has solved the problem of the choppy and sometimes incoherent playback.
Before anyone says it I know its not supported on a virtual machine but its the credit crunch :)
Feisal
07-24-2009 05:00 AM
Hi Feisal,
Just to add a quick note to the good info from Rick (+5 points Rick :)
Unity 7.x is now supported on VMware :)
Virtualizing Cisco Unity Messaging on VMware ESX
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/virtualization_design/guide/cuvirtualdg010.html
Hope this helps!
Rob
07-24-2009 05:48 AM
