craiglcve Fri, 07/17/2009 - 10:24
DMA is located under the Communications manager software page.
Voice and Unified Communications > Cisco Unified Communications Manager Version 7.1 > Unified Communications Manager Data Migration Assistant
It is version specific. For example if you were upgrading to version 7 you would go to that page you posted and then down to Cisco Unified Communications Manager Version 7.1 and you will see it in the Callmanager 7.1 software.
d.anthony.hadley_2 Fri, 07/17/2009 - 11:31
Thanks, I found it. The full path I took is below. The file never came up in the search. In any case, thanks.
Voice and Unified Communications > Ip Telephony> Call Control>Cisco Unified Communications Manager (CallManager)>Cisco Unified Communications Manager Version 7.1>Unified Communications Manager Data Migration Assistant
