LMS 2.5 ACS 4.2 integration
Answered Question
Jul 17th, 2009
I want to integrate LMS 2.5 with ACS 4.2
Does anyone had the documentation?
Correct Answer by Joe Clarke about 7 years 10 months ago
This is not possible. LMS 2.5 does not support ACS 4.2. If you need ACS 4.2 support, you will need to upgrade to LMS 3.0.1 or higher.
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Fri, 07/17/2009 - 11:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
