Language UC520
Jul 17th, 2009
Hi, I need install Spanish Language in the Cisco UC520. But this message is showed:
Validating package signature ... done
ERROR: Invalid package. Please verify if this is a valid package file.
What the exactly packet ??
UC500-CUE# show software versions
Installed Packages:
Software Version: 3.0.3
- Installer 3.0.3.1
- Thirdparty 2.3.1.0
- Bootloader (Primary) 2.1.14
- Infrastructure 2.3.2.0
- Global 3.0.3
- GPL Infrastructure 2.2.1.0
- Voice Mail 2.3.1.0
- Bootloader (Secondary) 2.1.15.0
- Core 2.4.0.1
- Auto Attendant 3.0.0.12
Installed Plug-ins:
- CUE Voicemail Language Support 3.0.0.0
- CUE Voicemail US English 3.0.0.0
Overall Rating: 5 (1 ratings)
ricardorojas123 Sun, 07/19/2009 - 09:29
I tried with the following files:
cue-vm-es_CO-lang-pack.2.3.4.1.prt1
cue-vm-es_CO-langpack.ise.3.0.3.prt1
cue-vm-es_CO-langpack.nm-aim.3.0.1.prt1
cue-vm-es_CO-langpack.nme.3.0.2.prt1
and this was showed:
I hope that the Special files fot the UC520 works ... thanks Rob !!
ricardorojas123 Sun, 07/19/2009 - 14:49
I tried with this files:
cue-vm-es_CO-lang-pack.2.3.2.prt1
cue-vm-es_CO-langpack.ise.3.2.1.prt1
cue-vm-es_ES-langpack.ise.3.0.3.prt1
cue-vm-langpack.ise.3.0.3.pkg
and the messages is the same ...
What can I do ??
Any suggest?
Daniel Alberto ... Thu, 11/12/2009 - 16:08
1.- Reducir la capacidad del voicemail a 480 minutos (1. show voicemail limits 2.config t 3.voicemail capacity time 480)
2.- Poner en una carpeta los dos archivos "cue-vm-langpack.ise.3.0.3.pkg" y "cue-vm-es_ES-langpack.ise.3.0.3.prt1"
3.- En la cue darle "software download upgrade cue-vm-langpack.ise.3.0.3.pkg" y después instalarla "software install add cue-vm-langpack.ise.3.0.3.pkg"
4. Seleccionar el idioma del menú el número "6" y después "x" para confirmar
5. Seleccionar el idioma español desde la cue en modo de configuración Global ("system language preferred es_MX")
Steps detailed
UC500-CUE# sh software versions
Installed Packages:
- Installer 3.0.3.1
- Global 3.0.3
- Core 2.4.0.1
Installed Plug-ins:
UC500-CUE# show voicemail limits
Default Mailbox Size (seconds): 775
Default Caller Message Size (seconds): 60
Maximum Recording Size (seconds): 900
Default Message Age (days): 30
System Capacity (minutes): 840
Default Prompt Language: systemDefault
Operator Telephone: 211
Maximum Broadcast Size (seconds): 300
Broadcast Message Age (days): 30
Broadcast Message MWI: disabled
Play Caller Id: enabled
Mandatory Message Expiry: disabled
UC500-CUE# conf t
Enter configuration commands, one per line. End with CNTL/Z.
UC500-CUE(config)# voicemail capacity time 480
UC500-CUE(config)# end
System Capacity (minutes): 480
Mailbox Selection: last-redirect
Daniel Alberto ... Thu, 11/12/2009 - 16:09
UC500-CUE# software download upgrade cue-vm-langpack.ise.3.0.3.pkg
WARNING:: This command will download the necessary software to
WARNING:: complete an upgrade. It is recommended that a backup be done
WARNING:: before installing software.
WARNING:: The system will briefly be brought to an offline state
WARNING:: This will terminate any active call and prevent new calls
WARNING:: from being processed.
Would you like to continue? [n] y
system/batch_mode: no such node/attribute
Software install using RAM
Downloading ftp cue-vm-langpack.ise.3.0.3.pkg
Bytes downloaded : 575607
Validating installed manifests ............complete.
- Parsing package manifest files... complete.
- Checking Package dependencies... complete.
- Checking Manifest dependencies for subsystems in the install candidate list..
- Checking Manifest dependencies for subsystems already installed...
complete
Running Script Processor for ui_upgrade
UC500-CUE# sh software directory download
KBytes Directory
572 /dwnld/pkgdata
Directory listings
Directory: /dwnld/pkgdata
total 572
drwxrwxrwt 2 root root 60 Nov 12 15:42 .
drwxrwxr-x 5 root daemon 120 Nov 12 15:43 ..
-rw-rw-r-- 1 root root 575607 Nov 12 15:42 cue-vm-langpack.ise.3.0.3.pkg
UC500-CUE# software install add ?
pkg file name pkg file name
url url
UC500-CUE# software install add cue-vm-langpack.ise.3.0.3.pkg
WARNING:: This command will install the necessary software to
WARNING:: complete an add-on install. It is recommended that a backup be done
This is add on installation.
Found new Add-On subsystem SID: a2ba4f96-3452-40c3-83ad-c442cb6bf42f Name: CUE 0
Found new Add-On subsystem SID: 3f968fd0-6598-48e2-be1c-4af6c2e02e02 Name: CUE 0
Found new Add-On subsystem SID: 683674a5-e6ef-4c97-8e05-efbba1e6fe47 Name: CUE 0
Ignoring identical versions of subsystem : [e2e81cc6-39b5-47e1-9f83-b83c897fc50]
Found new Add-On subsystem SID: f0a41398-3917-4d49-b5ab-c2b39a80c121 Name: CUE 0
Found new Add-On subsystem SID: c28339fa-f7ae-4732-85ab-fa6c68b5de0c Name: CUE 0
Found new Add-On subsystem SID: c4ca62e2-daff-40dc-b94e-bf20094bd700 Name: CUE 0
Found new Add-On subsystem SID: 49f09114-e0b0-4721-8b85-04be2064920c Name: CUE 0
Ignoring identical versions of subsystem : [27e5e2ab-1622-4c02-8a0a-cfad0d93214]
Found new Add-On subsystem SID: fa803d25-9c89-4171-a14c-ec12d6ed6b8c Name: CUE 0
Found new Add-On subsystem SID: cf860289-67ac-4886-9295-a41e4c7a8487 Name: CUE 0
Found new Add-On subsystem SID: 88f73a6c-884d-4838-b162-1b544dd6583f Name: CUE 0
- Checking Manifest dependencies for subsystems in the install candidate list...
complete
Running Script Processor for ui_install
Language add-ons found on the system (1):
Installed SKU Name (version)
* ENU CUE Voicemail US English (3.0.0.0)
Daniel Alberto ... Thu, 11/12/2009 - 16:10
Continuación:
Maximum 2 language add-ons allowed for this platform.
You may install 1 more language(s) from the following list:
Language Installation Menu:
# Selected SKU Language Name (version)
1 PTB CUE Voicemail Brazilian Portuguese (3.0.0.0)
2 DEU CUE Voicemail German (3.0.0.0)
3 FRC CUE Voicemail Canadian French (3.0.0.0)
4 ESO CUE Voicemail Latin American Spanish (3.0.0.0)
5 ITA CUE Voicemail Italian (3.0.0.0)
6 ESM CUE Voicemail Mexican Spanish (3.0.0.0)
7 ESP CUE Voicemail European Spanish (3.0.0.0)
8 ENG CUE Voicemail UK English (3.0.0.0)
9 FRA CUE Voicemail European French (3.0.0.0)
10 DAN CUE Voicemail Danish (3.0.0.0)
Available commands are:
# - enter the number for the language to select one
r # - remove the language for given #
i # - more information about the language for given #
x - Done with language selection
Enter Command:6
6 * ESM CUE Voicemail Mexican Spanish (3.0.0.0)
Enter Command:x
ui_install scripts executed successfully.
Starting payload download
File : cue-vm-es_MX-langpack.ise.3.0.3.prt1 Bytes : 32402300
Downloading payload(s) complete
Validating payloads match registered checksums...
- cue-vm-es_MX-langpack.ise.3.0.3.prt1 ...............................verified
The system will be brought to offline state for a brief period
and will be brought back to online state automatically
Generating the add-on-install work order :
Setting install started flag
returning fname /dwnld/.work_order
The system is back in online state
Shutting down processes ... Please wait
EXITED: probe exit status 0
EXITED: SQL_startup.sh exit status 0
UC500-CUE# sh softw versions
Installed Packages:
- Installer 3.0.3.1
- Global 3.0.3
- Core 2.4.0.1
Installed Plug-ins:
- CUE Voicemail Mexican Spanish 3.0.0.0
UC500-CUE(config)# system language preferred es_MX
Preferred language has been set to: es_MX
