NAC OOB VG HA Problem
Jul 17th, 2009
I have 2 NAC Appliances. I am having a problem with configuring HA on CAS. I have configured the Primary CAS in the following way.
The same service ip address on trusted and untrusted interface.
Heartbeat value is set to 15
The eth2 interface ip address in 192.168.1.253 on primary and 254 on secondary. Both the ip address can be ping.
The simialar config on the other CAS
Rebboted and i added it in the CAM.
Then configured the secondary CAS
After that both shows active /active and peer is dead.
Moreover i cannot ping each other ip address but i can ping gateway from both .
I have added each others name in hosts file but still they cannot ping each other by name even.
The configuration of switch connected to CAS CAS is given below.
interface FastEthernet0/13
description Connected-To-CASTrusted
switchport trunk native vlan 30
switchport trunk allowed vlan 12,33,34
switchport mode trunk
end
Switch#sh run interface fastEthernet 0/14
Building configuration...
Current configuration : 205 bytes
interface FastEthernet0/14
end
interface FastEthernet0/15
switchport trunk native vlan 31
switchport trunk allowed vlan 333,334
end
Switch#sh run interface fastEthernet 0/16
Current configuration : 167 bytes
interface FastEthernet0/16
end
Physical connectivity is fine.
