Jack and cable used for T1 connection
Answered Question
Jul 17th, 2009
We have a "smart jack" installation that connects to our router. The cable going from the smart jack to the router WAN interface seems to be a CAT5e cable with RJ-45 connectors at both ends.
Most network diagrams in training materials represent T1 Frame Relay connections as serial links.
Is the CAT5e cable wired different than a straight-through configuration? Is the port on the WAN port a T1 DSU card?
Seeking knowledge...
Correct Answer by paolo bevilacqua about 8 years 1 week ago
Yes is wired different and also the impedence is different. That is called a T1 cable with RJ48c connector.
The WAN port on arouter sometime is T1, sometime CSU/DSU, sometime something else. There is no fixed rule.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Fri, 07/17/2009 - 14:00
  • Hall of Fame,
    Founding Member
bflseanny Fri, 07/17/2009 - 14:40
Thank you so much.
I love this forum! I am already learning so much.
