Warning message
WAEs CAUSE HIGH CPU LOAD ON ROUTER 7609
Jul 17th, 2009
We had deploy a wae (7341) cluster at this time 2 waes, they are serving wccp web cache and spoofing services, we see the router 7609 increases its cpu load at 55% average and more during the peak hours,we want to know what we can do in order to reduce the router's cpu load
Thanks for your help.
tblancha Fri, 07/17/2009 - 14:27
  • Cisco Employee,
Is CEF turned on? Did you configure a service for out? If you are doing an out, then this is a process switched event. Look to do 61 and 62 in on the interfaces instead of anything out.
gbruque99 Fri, 07/17/2009 - 14:43
Yes Cef is ON,
On the interfaces the services wccp are configured like this
ip wcc web-cache redirect in
ip wccp redirect out
The 7609 has a supervisor engine WS-SUP720-3B
nchidamb Tue, 07/21/2009 - 06:10
What is the egress method you are using? Can you send us the output of 'show egress-method' from the WAEs that are attached to 76xx having spike in their CPU usage?
gbruque99 Tue, 07/21/2009 - 14:50
Hi, thanks for the help
This command is not supported by the WAE. We have a Wae 7341, ACNS 5.5.13
The WAE's had not experienced cpu high load neither spike.
What about to change the Supervisor Card from the 7609 router ?? Fron the current WS-SUP720-3B to another one..the question is wich one??
nchidamb Tue, 07/21/2009 - 16:15
Sorry, I didn't know you are using 7341 as ACNS device. I would not recommend changing the h/w at this point. Can you pl email me 'show tech' from the 7341. My id is nchidamb@cisco.com.
gbruque99 Wed, 07/22/2009 - 06:47
I send you the information requested about WAE.
