CUBE Licensing For Lab Router
Jul 17th, 2009
Should I permanently license my lab router for cube after 60 days? Is there some limited license that could be bought for a really small number of sessions (<<25)?
Jonathan Schulenberg Sat, 07/18/2009 - 08:19
Any IOS feature licenses must be purchased if you want a permanent PAK. If you are a partner you could purchase this under your NFR program at significant discount; that's exactly what that program is for.
If you are a customer the 25 concurrent call path license (FL-CUBE-25) has a list price of $2950. To my knowledge that is the lowest call path quantity you can order.
yusufbudi Tue, 06/11/2013 - 02:29
Hi Team
I have router 3800 series with voice support. ios sp-services. I want to try sip trunk
How to get the demo license FL-CUBE to my router
Paolo Bevilacqua Tue, 06/11/2013 - 03:39
Yusuf Budi Mulia wrote:
Hi Team
Contact a Cisco Reseller.
