Two Domains DNS
Hi, hope someone can help
I have a ASA 5510 with 2 domains connected to separate internal interfaces both NAT'ed to public IPs and one external interface with a public IP everything is working great apart from if one domain sends an email to the other.
Internal users on each domain resolve the other domain name to it's public ip. I have setup DNS rewrite but this has not solved the problem, all external users can access both domains.
Jim
pccw258103 Sat, 07/18/2009 - 21:09
Hi, where do the DNS place at??
Internal Interfaces or Outside interfaces
pccw258103 Sat, 07/18/2009 - 21:10
pccw258103 Sun, 07/19/2009 - 01:12
Hi, there is our network sample configuration that is worked fine.
Outside) Public network IP 202.20.1.0/24
(Inside) Pivate 192.168.100.0/24
*** Public IP 202.20.1.10 www nat map to private IP 192.168.100.10 www
access-list OUTSIDE extended permit tcp any host 202.20.1.10 eq www
!--- Simple access-list that permits HTTP access to the mapped
!--- address of the WWW server.
global (outside) 1 interface
nat (inside) 1 192.168.100.0 255.255.255.0
static (inside,outside) 202.20.1.10 192.168.100.10 netmask 255.255.255.255 dns
!--- PAT and static NAT configuration. The DNS keyword instructs
!--- the security appliance to rewrite DNS records related to this entry.
access-group OUTSIDE in interface outside
!--- The Access Control List (ACL) that permits HTTP access
!--- to the WWW server is applied to the outside interface.
policy-map type inspect dns MY_DNS_INSPECT_MAP
parameters
message-length maximum 512
!--- DNS inspection map.
policy-map global_policy
class inspection_default
!--- DNS inspection is enabled using the configured map.
