2960 QoS and Port-Security Template
Jul 18th, 2009
  • Bronze, 100 points or more
I've been burned a few times by Port-Security and having ports err-disabled due to it…any thoughts on this template for my 2960 switches. Came from the WebGUI port-macro thing….unfortunately this is from remote lab and I don't have anything in front of me to test;
config t
udld aggressive
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos rewrite ip dscp
macro global description cisco-global
errdisable recovery cause link-flap
errdisable recovery interval 60
spanning-tree mode rapid-pvst
spanning-tree loopguard default
interface range f0/1 - 48
description Host/IP Phone
no shutdown
switchport access vlan 2
switchport mode access
switchport voice vlan 3
switchport port-security maximum 2
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
mls qos trust cos
spanning-tree bpduguard enable
macro description cisco-phone
spanning-tree portfast
end
We plug in phones, then PC to back of phone. Also I'm thinking for 7911/79411 phones I should have just “mls qos trust”. Also the LAN Lite 2960 doesn't have “auto-qos voip Cisco-phone” so I have to manully set qos … You get what you pay for….
