jimmysands73_2 Sat, 07/18/2009 - 13:17
  • Silver, 250 points or more
When I was doing my NetAcad and trying to get ospf working over fr, I had to use the commad ip ospf network broadcast before my ospf routes were sent. I think. Eventually I got the FR working with OSPF though.
If you would post alittle bit more info, I'd be happy to look it over.
Reza Sharifi Sat, 07/18/2009 - 13:19
  • Cisco Designated VIP,
    2017 LAN
I am not sure if I understand the question
Are you trying to build a frame relay cloud?
If yes, then you need a router like a Cisco 2522 as your frame relay switch.
Then you connect all your serial cables from all the other routers to this
Switch/router to simulate frame relay
Reza
Lijesh NC Sun, 07/19/2009 - 01:23
hi sharif,
Thanks for the reply ..yes you are right . i am trying to build a frame relay cloud ..can i know the config (frame-relay cloud )can i achive this by dinamips ..
hitesh_patel Sat, 07/18/2009 - 19:43
Hi Lijesh,
you need any low end cisco router with four or more serial interfaces to fit to your topology. You can have 2522 with 10 serial interfaces or can have any 2600 with NM-4AS or NM-8AS card. The rest is easy to configure it as frame relay switch. Here is the link which shows how to configure.
http://www.thebryantadvantage.com/Frame%20Relay%20Switch.htm
Hitesh Patel
Lijesh NC Sun, 07/19/2009 - 01:27
Hi Hitesh,
Thanks for the reply this was what i was loolkig for.will i b able to achive using dinamips ... any way i will give an try and let you know the status ...
lijesh
