Port forwarding issue
Jul 18th, 2009
IOS: 12.4(22)YB/ CME 7.1
I used CCA 2.0.1 for initial config.
I can't seem to get port forwarding working...anyone see what I am missing?
Do you have to specifiy "ip routing"?
Steven DiStefano Mon, 07/20/2009 - 07:10
I just used CCA 2.0.1 to configure a NAT for port 1024 coming in on FE0/0 to map to 1024 (TCP) on an inside 192.168.10.x address on my 12.4(20)T2 system and I am able to get in and use the application.
I see the same commands as you shared in your config:
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static tcp 1024 interface FastEthernet0/0 1024
access-list 1 remark SDM_ACL Category=2
access-list 1 permit
Are you sure your terminal server is ready to receive connections?   Can you forward to a different application to rule that out?
Steven Smith Mon, 07/20/2009 - 07:34
Are you trying to forward TCP 3389?  Or is it something else you are trying to forward?
