sticky by cookie not working
Jul 18th, 2009
Folks I have a situation where sticky by cookie is not working. When 2 nodes are UP it does not stick to the same node. When one node is up sticky is fine
See below my config
serverfarm host 24.8.1.10-80
probe TCP_21511
rserver test1 21511
inservice
rserver test2 21511
inservice
sticky http-cookie sticky_xwalk 24.8.1.10-80_STICKY
cookie insert browser-expire
replicate sticky
serverfarm 24.8.1.10-80
policy-map type loadbalance first-match 24.8.1.10-80_POLICY
class class-default
sticky-serverfarm 24.8.1.10-80_STICKY
what am i doing wrong?
huangedmc Sat, 07/18/2009 - 22:21
The config looks correct - that's how we have ours set up.
When you look at the http header on a test workstation, do you actually see the cookie?
cricketbuff Sun, 07/19/2009 - 03:57
On the workstation we see the cookie but when 2 nodes are active in a serverfarm it does not stick to the same node.
huangedmc Mon, 07/20/2009 - 03:11
I'm curious to know if the session made it into the sticky database...
Do you see it when you do "show sticky database static?"
Have you opened a TAC case?
Gilles Dufour Wed, 07/29/2009 - 04:06
  • Cisco Employee,
you may need to enable persistence rebalance with a parameter-map.
Gilles.
