Performance Issue with Router
Jul 19th, 2009
I have performance Issue once I have Router between Internet and Microsoft ISA.
If I connect Internet directly with additional NIC on Microsoft_ISA it works great...
I didnt find any communication issue between router and ISA.
Can someone advice, here is router configuration**
interface FastEthernet0/0
description Connected to service-provider
ip address 10.10.10.2 255.255.255.252
ip nat outside
interface FastEthernet0/1
description Connection to LAN
ip address 192.168.1.100 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip nat inside source list 99 interface FastEthernet0/0 overload
access-list 99 permit ip host 192.168.1.200 any
Overall Rating: 0 (1 ratings)
Joseph W. Doherty Sun, 07/19/2009 - 03:35
What model router and how much FastEthernet bandwidth is possible?
ronald.ramzy Sun, 07/19/2009 - 03:56
The Router is 2811 with 2 fastEthernet.
There is no bandwidth command configured on Interfaces.
Interfaces dont have any error.
Will it make a difference if I NAT public to private IP instead of NAT Overload.
Joseph W. Doherty Sun, 07/19/2009 - 04:11
Although a 2811 comes with two FastEthernet interfaces, its forwarding performance isn't really capable of delivering 100 Mbps, even discounting NAT load, which is why I asked how much of the FastEthernet bandwidth might be used.
PS:
If 10 Mbps is acceptable throughput, you might reconfigure your FastEthernet interfaces to run at that setting and see how the 2811 performs for you.
ronald.ramzy Sun, 07/19/2009 - 04:17
I have tested with Speed and Duplex as auto. My Service Provider bandwidth is 5MB only.
You (PS) is to change bandwidth to 10mbps you mean.
Do you think NAT_Overload is causing issue, any other recommendation.
pompeychimes Sun, 07/19/2009 - 06:51
  • Bronze, 100 points or more
With the info you've presented I don't see this being a NAT issue. It sounds like you have two NICs on your ISA Server. Do you get the same results with both NICs? How about testing without the ISA Server in the mix?
ronald.ramzy Sun, 07/19/2009 - 07:22
With ISA having Two NIC ; it works great, but when with natted IP on Router and ISA one nic it has performance problem.
Now I removed ISA and plugged BLUECOAT but still performance issue.
Without Router NAT all seems working...
pompeychimes Sun, 07/19/2009 - 07:28
So both ISA NIC's produced the same problem? How about my suggestion to remove the ISA from the equation?
Are you doing any NAT on the ISA?
ronald.ramzy Sun, 07/19/2009 - 12:14
With Two NIC on ISA and no router it works great. I define public IP on one interface and private IP on another interface.
I am not sure where is the issue.
pompeychimes Sun, 07/19/2009 - 16:29
From your responses it does not seem that you understand what I'm asking / suggesting.
Joseph W. Doherty Sun, 07/19/2009 - 16:51
"You (PS) is to change bandwidth to 10mbps you mean. "
I mean to run the interfaces physically at 10 Mbps, if running at 100 Mbps.
"Do you think NAT_Overload is causing issue, any other recommendation. "
It might, but reading http://www.cisco.com/en/US/tech/tk648/tk361/technologies_q_and_a_item09186a00800e523b.shtml#qa7, can't be sure (there's also the overload issue).
Other issues that come to my mind have been 100 Mbps bursts, packet fragmentation, interface drops, and CPU load.
If you could provide interface and CPU stats when router is running "slow" but with what you believe its maximum performance, it might provide additional clues.
cisco24x7 Mon, 07/20/2009 - 06:09
  • Silver, 250 points or more
"Although a 2811 comes with two FastEthernet interfaces, its forwarding performance isn't really
FastEthernet bandwidth might be used."
I would like to challenge josephdoherty's assertion on this. How did you come up with this assumption?
As seen below, the cisco 2811 can push almost 100Mbps with some NAT load using Iperf:
c2811#sh int f0/1
FastEthernet0/1 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 001e.7a6d.8149 (bia 001e.7a6d.8149)
Description: LAB_INTERFACE
Internet address is 192.168.15.246/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 242/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/4025/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 95050000 bits/sec, 7871 packets/sec
30 second output rate 7000 bits/sec, 8 packets/sec
14988854 packets input, 2349426431 bytes
Received 13806683 broadcasts, 0 runts, 0 giants, 2125 throttles
38010 input errors, 0 CRC, 0 frame, 0 overrun, 38010 ignored
0 watchdog
406395 packets output, 65459960 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier
c2811#
c2811#sh process cpu | i five
CPU utilization for five seconds: 79%/75%; one minute: 61%; five minutes: 34%
c2811#
c2811# sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 28-Apr-09 13:09 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
c2811 uptime is 3 weeks, 2 days, 20 hours, 14 minutes
System returned to ROM by reload at 17:45:33 UTC Fri Jun 26 2009
System image file is "flash:c2800nm-advipservicesk9-mz.124-15.T9.bin"
Joseph W. Doherty Mon, 07/20/2009 - 09:21
"I would like to challenge josephdoherty's assertion on this. How did you come up with this assumption?"
Challenge away ;)
Seriously, though, assumption is based on PPS rating as published within Cisco's Portable Product Sheet - Router Perf which notes "Fast/CEF Switching PPS" as 120,000 for a 2811. Beginning of document also notes "Numbers are given with 64 byte packet size, IP only, and are only an indication of raw switching performance. These are testing numbers, usually with FE to FE or POS to POS, no services enabled."
Knowing that wire-rate Ethernet, at 100 Mbps, for 64 byte sized packets, requires 148,809.6 PPS, the 120,000 PPS seems to be unable to guarantee 100 Mbps. (NB: The Cisco performance sheet actually computes bandwidth for 120,000 as 61.44 Mbps, but they also don't seem to take into account all L2 overhead.)
So assuming Cisco's reference performance numbers are correct, also assuming, when we think, today, of any bandwidth, we're assuming its full duplex, I assume a 2811 can not guarantee 100 Mbps. (NB: RE: "full duplex", perhaps you don't assume this, since I see your example iperf test was only pushing 100 Mbps in one direction.)
Beyond assumptions, I've also stressed tested a 2811 and I hit 100% CPU before reaching 100 Mbps throughput, even unidirectional. (NB: I also noticed, your output stats showing arrival bandwidth utilization, but not also egress bandwidth utilization?)
Also looking at your posted stats, did you notice?
"Input queue: 0/75/4025/0 (size/max/drops/flushes"
I don't know about you, but I expect a device that can handle 100 Mbps shouldn't be dropping any packets. You might note the drop rate is low, but why is the router dropping any packets? Load perhaps?
Also we see:
Perhaps more symptoms of a router that can't sustain 100 Mbps load?
Given the above, to be more precise, I assert a 2811 can't always guarantee 100 Mbps, especially duplex. However, for larger packets, and unidirectional, a 2811 might provide 100 Mbps throughput. This is also why I wrote "really capable of delivering 100 Mbps" rather than a simple "incapable", "unable" or "never". I do apologize if my original imprecision was misleading, but sometimes I'm intentionally not precise since I don't believe such precision always assists. If there are questions, they can be followed up in additional questions, such as David's post to which I'm responding; and this I think is good!
Giuseppe Larosa Mon, 07/20/2009 - 10:20
  • Hall of Fame,
    Founding Member
Hello Joseph, David
Absolutely yes
(rethoric question I suppose)
Hope to help
Giuseppe
Joseph W. Doherty Mon, 07/20/2009 - 16:20
"(rethoric question I suppose) "
It was (as was the preceeding question).
Pavel Bykov Mon, 07/20/2009 - 06:35
One theory are output drops.
Do this:
policy-map SHAPE
class class-default
shape average 5000000
service-policy output SHAPE
If your connection to ISP is really only 5M, this will help a lot on the upstream side.
Persuade provider to do shaping instead of policing on the output to your site on their PE.
Remember how TCP works. If you create a policer for 10Mbps on a 100Mbps interface, it one TCP session will only be able to use up only about 1.5Mbps on average. That's a huge difference. With shaping, one TCP session will be able to use almost all of the link.
Ofcourse with many users, there will be more TCP sessions and therefore higher overall throughput (up to the speed of the policer).
But it all depends on what apps are used and what is tested.
Joseph W. Doherty Mon, 07/20/2009 - 09:39
Pavlo, excellent information, although if we keep in mind, if I understand issue correctly, additional insertion of router reduces perfomance, I'm unsure that addition of a shaper, assuming one isn't already configured, would improve performance vs. decrease of performance when router added. Does this make sense?
As I asked in one of my prior posts, we need more information because I think we're trying to ascertain why addition of the router is reducing performance.
Something like a shaper could indeed enhance performance over no router or router with basic configuration, but again, the mystery is why a basic router configuration is reducing performance vs. no router.
Joseph W. Doherty Tue, 07/21/2009 - 03:27
More so the the "ignored" errors on fastE 0/1; of concern are the many "output errors" and "late collision". Duplex mismatch? Bad or wrong spec cable?
PS:
NB: "Number of late collisions. Late collision happens when a collision occurs after transmitting the preamble. The most common cause of late collisions is that your Ethernet cable segments are too long for the speed at which you are transmitting. "
vishwancc Tue, 07/21/2009 - 06:19
Hi slider,
"Remember how TCP works. If you create a policer for 10Mbps on a 100Mbps interface, it one TCP session will only be able to use up only about 1.5Mbps on average. That's a huge difference. With shaping, one TCP session will be able to use almost all of the link"
Do you mind explaning this in a little brief.
Chao
Vishwa
cisco24x7 Tue, 07/21/2009 - 18:13
Challenge away ;)"
I don't think the data that joseph provided is accurate. See below:
30 second input rate 97738000 bits/sec, 9023 packets/sec
30 second output rate 64403000 bits/sec, 5321 packets/sec
The rest of the output:
c2811#sh int f0/1
reliability 255/255, txload 164/255, rxload 249/255
Last clearing of "show interface" counters 00:02:19
Input queue: 5/75/0/0 (size/max/drops/flushes); Total output drops: 0
1264186 packets input, 1715894352 bytes
Received 579 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
728879 packets output, 1102886611 bytes, 0 underruns
c2811#
Clearly, the 2811 platform can deliver 100Mbps throughput without any issues. Not sure how did your testing but as you can see with mine, performance is pretty good even with some NATs.
Joseph W. Doherty Tue, 07/21/2009 - 19:10
What data do you believe I've posted that's inaccurate?
I'm guessing you still disagree with my original "really capable" adjectives. If so, again, another way to look at that is "really capable" means there's no question, and from your final remark you believe the 2811 is fully capable of 100 Mbps (i.e. "Clearly, the 2811 platform can deliver 100Mbps throughput without any issues.") Yet, even with your latest interface stats, you still have not shown 100 Mbps egress! Forwarding performance is traffic that transits the device, not just received on an interface. You're also using large to max size packets. Try minimum size packets and see how that behaves. Also, although your new stats don't show the same interface errors the first post did, how do you explain the first post's interface errors stats? Lastly, on your latest stats, did you notice:
Input queue: 5/75/0/0 (size/max/drops/flushes?
If you have FastE in and FastE out, why are any packets being queued? (To me, that's an issue.)
PS:
BTW, I can provide a copy of the performance sheet I was looking at, if requested, but I believe the numbers haven't changed for the 2811 on the latest revision.
As to how I had tested a 2811, I used a utility, pcattcp, and pushed 100 Mbps of UDP through a 2811. I didn't pay much attention to the packet sizes. I did note, receiving interface showed 100 Mbps (like yours), but egress was far short (about half?) and CPU hit 100%. (Purpose was to estimate how much of a full T3 2811 might handle.)
cisco24x7 Tue, 07/21/2009 - 19:34
"If you have FastE in and FastE out, why are any packets being queued? (To me, that's an issue.)"
I did not clear the counters before running the test in my first post so there were errors and that output is not an accurate one. The 2nd output is an accurate reflection of the test.
Of course, if you use 64 bytes size packet, then you will not be able to push 100Mbps through put. I am mainly talking about ftp, scp or oracle sqlnet traffics. In that case from what I see, the router can forward close to 100Mbps throughput without issues. My NMIS system confirms that I am getting close to 100Mbps on the servers in front and behind the routers. The reason I am seeing packets being queued is because the I am pushing and pulling iperf traffics on the same server and that the server behind the router is a dell optiplex P-III 800Mhz. The result would have been closed to 100Mbps both way if the server is a quad-cpu/quad-core with lot of RAM.
Joseph W. Doherty Tue, 07/21/2009 - 20:46
"I did not clear the counters before running the test in my first post so there were errors and that output is not an accurate one. The 2nd output is an accurate reflection of the test. "
Ah, but the queued packets, in your 2nd post, which you note "is an accurate reflection of the test", still indicates a performance issue. Consider, data can't arrive faster than 100 Mbps (or shouldn't, although it might, but we'll assume it doesn't), and if data forwarded at 100 Mbps, there should be no queuing. I.e., packet arrives, packet leaves.
I'm also glad to read your 2nd output is accurate, although would have liked to have seen the paired ingess/egress interfaces (especially 100 ingress to 100 egress).
"Of course, if you use 64 bytes size packet, then you will not be able to push 100Mbps through put. I am mainly talking about ftp, scp or oracle sqlnet traffics."
Oh, you're talking about certain types of traffic. I wasn't, which is why I asserted the 2811 "isn't really capable" because, to me, really capable means there are no conditions.
To put this even another way, if a device can not deliver wire-speed/line-rate for all traffic, then I believe the device "isn't really capable" for that bandwidth. This is not to be confused with it might sometimes deliver wire-speed/line-rate but under certain conditions.
My belief is a 2811 is not a wire-speed/line-rate device for 100 Mbps Ethernet especially duplex. Do you disagree?
Now you also write "In that case from what I see, the router can forward close to 100Mbps throughput without issues." "close to"? Did you mean the 64 Mbps shown for egress in your 2nd post for near maximum packet sizes? Or, did you mean what your NMIS is reporting?
"The reason I am seeing packets being queued is because the I am pushing and pulling iperf traffics on the same server and that the server behind the router is a dell optiplex P-III 800Mhz. The result would have been closed to 100Mbps both way if the server is a quad-cpu/quad-core with lot of RAM."
So you're thinking a more powerful host would create less queuing on the router by pushing a full 100 Mbps each way? Is this a fact or assumption? (I would assume the opposite.)
