Configuring an IPsec Router Dynamic LAN-LAN peer and VPN clients
Jul 19th, 2009
I need to connect remote vpn and site to site vpn on same interface, but I am not able to connect site to site vpn, and didnt find any debug messsage of isakmp either, I have attached the configuration, please help me out
pompeychimes Sun, 07/19/2009 - 07:24
On the hub router i see "crypto map mymap" configured on f0/0 but there appears to be no crypto map called "crypto map mymap" configured on the router.
Elvin Arias Sun, 02/06/2011 - 12:30
The problem is that you crypto dynamic map entry has a higher priority than the crypto map static, so you must change it to have all in order.
in other words you crypto dynamic map must have a higher sequence number than the static crypto map
Here is an example:
crypto map VPN 10 ipsec-isakmp
set transform-set TRASNFOR-IPSEC
set peer X.X.X.X
match addresss ACL
crypto dynamic-map VPN 50000
If don't work you can reply [email protected]
