07-19-2009 08:10 AM - edited 03-14-2019 04:22 AM
Hi, I am fairly new to this product, I am wondering if there is any doc indicated the default queue limit settings, I couldn't find in the script that the set value node, so I guess it must be running using the default value. please advise, thanks
07-24-2009 02:57 PM
The percentage of calls queued and the average time spent in the queue are determined by the service level desired and by agent staffing.
07-25-2009 12:00 AM
It is common for those coming from a TDM PBX background (say Avaya) to ask how big the queue is. Since on those platorms one can set a limit on the number of calls one can put into the ACDQ.
Once full, other callers will get a busy signal. On extremely busy call centers, this seems like a reasonable way to block calls when under heavy load.
ICM (UCCE) doesn't have a fixed limit like this, and the Call Router can keep queuing calls. There probably is a software limit, and it may be set in the Router registry. I don't know what it is.
To try to avoid putting callers into a "queue" when the number already queued is very high, you could check this in the Script before the "Queue To Skill Group" node - if this is what you need to do.
Geoff
07-25-2009 06:24 AM
I am new to this world as well, I guess in the real practice, all you need to do is after carefully sizing the resources and pick a realistic queue limit as a globel user variable and set the variable as the one you picked
11-05-2009 12:03 PM
I am looking for this solution for our icm contact center. Did you find the solution.
Thanks in advance
