07-19-2009 01:09 PM - edited 07-03-2021 05:50 PM
I have a customer that would like to mount the 1522's on top of Buildings. They already ordered the Pole Mounting kits - which include a bracket that would allow them to flush mount to the walls. The customer is looking for something like the 1310 mounting kits or the old 1510 roof top kits. Does anyone have suggestions? Will the 1310 roof top kit work for the 1522?
Thank you,
Rudy
07-19-2009 09:40 PM
If you buy a couple of U-Bolts and clamp the 1252 bracket to the pole this would work easy enough.
Cheers
Mat
07-20-2009 11:22 AM
I understand the U-bolts but they have not pole or in this case like the metal arm that comes with the 1310 Rooftop kit. I wonder if they are compatible.
07-20-2009 03:10 PM
I have developed a MESH AP enclosure that mounts to a standard parking lot light pole as well as to a building appearing to be a square light box. If you're interested let me know. Cost is about 500.00 each.
