CSM Problem
Jul 19th, 2009
Folks,
When I import a config for a router from a notpad file and try to push it to a device, it automatically shutsdown the interface??? I made sure I put a no shut on all interfaces in the config file before importing it too csm, but when csm pushes it to the device, it does it with a shutdown option, is it a bug??? I am running 3.1. Please help, will surely rate this post.
Farrukh Haroon Wed, 07/22/2009 - 23:42
Did you try doing this through a "flexconfig" option?
OR perhaps put the 'no shut' as the last (or first) command in the text file e.g.
int gig 0/0
ip nat inside
no shut
Farrukh
NAVIN PARWAL Thu, 07/23/2009 - 02:53
I had "no shut" as the last command under the interface, does it matter?
Farrukh Haroon Thu, 07/23/2009 - 18:30
Normally NO, but with CSM anything is possible.
I would use the Flexconfig option with a 'no shut' just to test things out.
Farrukh
