Strange Behavier of Cisco Agent Desktop Integrated Browser
Jul 19th, 2009
Hi All
I found that the integrated browser will parse number in to link as phone number, for example:
<html>
<p>2101495039</p>
</html>
The browse will handle 2101495039 as a link
It should be a feature but I don't need, Can I disable it?
Sergey Tregubov Mon, 07/20/2009 - 06:25
Yes, you can disable it from Cisco Desktop Administrator --> Desktop Configuration --> Work flow Groups --> ... -->User Interface --> Browser Setup
WalterPang Mon, 07/20/2009 - 23:06
Thanks you reply
However, I cannot find any option under Browser Setup to disable the feature.
From the tab page of Browser Setup.
there are only few options as below.
Allow Address Editing,
Number of Workflow,
Enable Integrated Browser
Am I getting something wrong?
I am using UCCX 7.0, Build 6.6.1.100.
d.gavin Fri, 09/11/2009 - 07:40
Did you ever get an answer for this? I need to disable this "feature" also.
