Nahassamad_2 Mon, 07/20/2009 - 02:37
Thanks for the response..
Yes you are right.I have tried this. Please see my scenario.
100 and 101 are my extension. If any calls comes to 100, both extension should ring. I have created a line group and assinged these two extension to that group with pilot 100 and the distribution algorithm is Broadcast. But i doesnt work. I think partition issue or something.
Please advice..
marina.kaminski Mon, 07/20/2009 - 02:42
If you want both phones to ring when a call comes to 100, your phones should be 101 and 102 (for example). You cannot have the same number assigned to the phone line and hunt pilot. The idea behind the hunt groups is having one "real" number to recieve calls and the the CM should distribute the calls to other phones based on the algorithm you choose.
