Cisoworks LMS 3.1 vs Whats Up Gold
Marvin Rhoads Mon, 07/20/2009 - 05:42
The Device Fault Manager (DFM) component of CiscoWorks can be configured to send notifications.
However, if your network is comprised of multi-vendor equipment, CiscoWorks and its component applications does not generally provide any of that sort of rich functionality.
CiscoWorks is designed and intended to manage all-Cisco networks. It depends on a tight integration with the software of the managed devices and expects data in specific well-established formats and exploits protocols such as Cisco Discovery Protocol (CDP) to provide a comprehensive view of your network.
CiscoWorks overview:
DFM details:
See specifically Chapter 5 of the DFM User Guide:
Hope this helps. Please rate helpful posts.
Marvin Rhoads Mon, 07/20/2009 - 13:09
Yes. DFM's default polling interval is 4 minutes and it could be scaled down to 30 seconds.
As with all settings, I'm sure you could impact either the CiscoWorks server or the network devices with excessive polling. For instance, polling every device in a 2,000 device network every 30 seconds is probably too much :)
Start with the defaults, establish a performance baseline, and go from there.
You could also use alternative tools such as the Embedded Event Manager (EEM) in IOS to fire off alerts or log messages when certain thresholds or conditions occur.
