Is CSCsr89144 fixed on ASDM 6.1(3)
Jul 20th, 2009
I have just run in to this ridiculous ASA bug where ASDM stops working if uptime is over 1 year.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsr89144
Could someone please tell me if CSCsr89144 is fixed in ASDM 6.1(3) as this is the version I have in most sites?
I cannot find a definite answer.
Jerry Ye Mon, 07/20/2009 - 07:25
  • Cisco Employee,
Hi Michael,
It is not fixed in 6.1(3). It will be fixed in 6.1(5) and later release.
HTH,
jerry
mikedelafield Mon, 07/20/2009 - 07:38
Thanks for the quick reply.
Does ASDM 6.1(5) operate okay with ASA image 8.0.4?
Thanks.
Jerry Ye Mon, 07/20/2009 - 08:06
  • Cisco Employee,
Hi Michael,
I have not test it personally. I think you might want to install it in a small set of ASA's and test it.
jerry
mikedelafield Mon, 07/20/2009 - 08:12
Thanks again.
I have a spare and I will test.
I cannot believe there is no other way around this bug!
Mike
mikedelafield Mon, 07/20/2009 - 23:41
Could someone please tell me if I only change the ASDM image path does the device need a reboot?
I presume the device continues operating normally and it only affects the ASDM GUI itself?
The next time I open ASDM will it should then open with the new image? I hope?
Thanks.
