Right Fax with CCM
Jul 20th, 2009
hi all,
I have Right Fax 9.4 which will integrate with VG to utilize its PRI for incoming and outgoing faxs .... right now ccm and gateway are integrated to each other via MGCP .. some one told me for utilizing the PRI of VG for faxes its better you should configure H.323 between CCM & VG bcoz with MGCP there are alot of issues !!!!
does some one has successfully deployed Right Fax utilizing VG PRI having MGCP configure b/w CCM & VG ..
I have CCM 6.1
