Route Map - ASA 5540 - 2 ISP
Jul 20th, 2009
We have 2 ASA 5540's in active passive failover connected to one of our ISPs. We have other firewalls that have another ISP as their gateway. We want to consolidate and run both ISPs on the ASA 5540s. What I want to do is use the IP address' from the one ISP for our servers that need to be accessible from the outside. What I want to know is will route-map be the best way to achieve this other than BGP? On the Inside interface of the ASAs there is a Procurve Layer 3 switch that will be the gateway of all of the servers, and the layer 3 switch has the ASAs as its default route. Thanks in advance
mmacdonald70 Thu, 07/23/2009 - 03:37
ASA can not do policy based routing or BGP. If the procurve can to PBR, you could set up the two ASAs in Active/Active and use one context for one ISP and the other context for the other.
