Cisoc 2611 Xml
Jul 20th, 2009
I am having Cisco 26211 XML router. with 2 inbuilt Ethernet interface and 2 port VIC FXS in NM2v card. I want to install one more Ethernet card in the same router. please provide the part number
Giuseppe Larosa Mon, 07/20/2009 - 10:27
Hello Thiru,
look for NM 1FE I don't think NM 2FE is supported on 2600XM (it should be on C3640 or C3660)
Hope to help
thiru.vel10 Mon, 07/20/2009 - 11:50
I have checked with Cisco , they said that this card not in sale , please advice me any other option pleas e
Leo Laohoo Mon, 07/20/2009 - 19:11
The only FE cards for the 2600 is the NM-1FE. This card has been end-of-sale for years now. You now have two options:
1. Upgrade your router; or
2. E-Bay
Hope this helps.
thiru.vel10 Mon, 07/20/2009 - 21:12
Thanks for this information; NM-1FE card is available in Ebay. I need one more information. I am using 2611xml router. Already I have installed the VIC FXS card in NM2V card. Only one slot is free. I want to know whether the VIC FXS card will support in Wic Slot ?. So that I remove the VIC FXS card from NM2V card and install the NM-1 FE card. Please advice me on this. “ I am not sure whether VIC FXS card will support small slot or not “
Leo Laohoo Tue, 07/21/2009 - 14:59
The c2600 has only one NM slot.
Do you need a routed port? If not, get a switch. If you do, then I recommend you use a different router.
