CM 4.1- How to get report of total calls in a given day?
Answered Question
Hi, I have CM 4.1. I was tasked with finding out how many calls we get in a given month/week/day. Incoming and outgoing, and as specific as a single extension.
Is this sort of reporting built in to CM, or do I require a 3rd party program? If so, what would you recommend for less than 100 users?
Thanks!
Correct Answer by Jaime Valencia about 7 years 6 months ago
You can use CAR for those purposes
CDR Analysis and Reporting
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/4_1_3/ccmsrva/sacar1.html
You can look at the reports that are available in the link.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
