DDNS - CCA
Marcos Hernandez Mon, 07/20/2009 - 13:45
  • Blue, 1500 points or more
DDNS is not configurable today via CCA, but it is a committed feature for our next release, 2.1. Stay tuned.
Marcos
Based on the following config items, where do I put my dyndns.org username and password?
! Define the DDNS global settings
ip domain lookup source-interface FastEthernet0/0
ip domain name dyndns.org
ip ddns update method method1
http
add
! As there is a “?” in the CLI – there will be an error if you copy / paste this line as is. You need to
! first paste the CLI before the “?”, then hit “Ctrl +V”, type ? and then paste the rest of the CLI
http://uc520multi:[email protected]/nic/update?system=dyndns&hostname=[email protected]/nic/update?system=dyndns&hostname=&myip=
interval maximum 2 0 0 0
interval minimum 1 0 0 0
Configure WAN interface for DDNS and VPN
description $FW_OUTSIDE$
ip dhcp client update dns
ip ddns update hostname SANJOSE-UC520.dyndns.org
ip ddns update method1
ip address dhcp
ip access-group 104 in
ip nat outside
ip inspect SDM_HIGH out
ip virtual-reassembly
duplex auto
speed auto
