3640 No IOS image
Jul 20th, 2009
I have a Cisco 3640. I was trying to upgrade the image. Is there a way to load the new ios image from rommon? This router has no ip configs. How do you configure ip address, subnet, and default gateway? so i can load from a tftp server.
Overall Rating: 4 (3 ratings)
Leo Laohoo Mon, 07/20/2009 - 14:43
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Xmodem Procedure for Downloading a Cisco IOS Software Image onto a Cisco 3600 Router
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml#proc_3600
ROMmon Image Download via the Console Port Using Xmodem with Increased Console Speed
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008009433b.shtml#image
Hope this helps.
Jon Marshall Mon, 07/20/2009 - 15:15
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
No, you shouldn't.
Jon
Jon Marshall Mon, 07/20/2009 - 15:23
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
If tftpdnld is available then that is usually faster than xmodem. But it is not always available whereas xmodem usually is.
Jon
Joseph W. Doherty Mon, 07/20/2009 - 16:55
As Jon notes, tftp is usually (much) faster, but if you do have to load via console port, some tricks:
Increase port speed to max (between devices)
Use most efficient file transfer protocol (supported between devices), e.g. xmodem-1k, y-modem, z-modem
Load smallest IOS image you can find to boot box, then load intended image via normal tftp or ftp.
joezuend007 Tue, 07/21/2009 - 14:52
Thank you all for your help!!! This was the first time I used this thing and I have to say wow!!
Leo Laohoo Mon, 07/20/2009 - 17:19
  • Hall of Fame,
    2017 LAN, Wireless
TFTPDNLD and 3640? I don't think 3640 supports TFTPDNLD (if I'm not mistaken).
You can increase the xmodem speed if you follow the second link I posted earlier. Here it is again:
Hope this helps.
