Prompt Management Not Working
I setup the prompt management number using CCA.  It will not work.  When you dial the number, it rings a few times, then rings a couple more times after making a noise, then a voice answers saying there is a problem with the system.  I checked to make sure a dial-peer is created for the prompt management.  It is the same configuration as the voicemail dial-peer except for a different extension.  The voicemail dial-peer works.
Anyone have an idea?
Marcos Hernandez Mon, 07/20/2009 - 17:22
  • Blue, 1500 points or more
Jason,
Can you session into CUE and share the piece of configuration under:
ccn application promptmgmt aa
Marcos
Marcos Hernandez Mon, 07/20/2009 - 17:24
Also, post the configuration blurb that has the ccn trigger for the prompt management service:
ccn trigger sip phonenumber
Marcos
Marcos Hernandez Tue, 07/21/2009 - 12:36
Jason,
What is the exact prompt that you get from CUE when it fails?
Marcos
Marcos Hernandez Wed, 07/22/2009 - 06:31
Hmmm. This script is built into the PKG. In any case, I am happy to hear this is working now.
Marcos
